Replacing instant cluster https certificate
This thread has been viewed 39 times
  • 1.  Replacing instant cluster https certificate
    Posted Aug 26, 2021 11:49 AM
    I have a long standing issue  with replacing the https cert on my instant cluster ( 8.8.0.1) but it has been happening in ever previous release.
    I create an appropriate upload file by
    Copying  cert into file1.pem
    Append the cert CA chain  by cat <cachain.pem>  >>file1.pem
    Append the key by typing
    cat <keyfile.pem >>file1.pem
    File1.pem then has
    I then upload this file onto the instant cluster VC
    If I get the format of the file wrong, then  when i log back onto the VC the https cert used is still the old one but more annoyingly if i go to management/certificates  you cannot see the certs on the VC, the web page just blanks out.
    The last time I fixed this by using airwave to uplaod the cert but that is no longer possible.
    Can you upload a new cert via the cli?
    Rgds
    Alex
    Alex Sharaz
  • 2.  RE: Replacing instant cluster https certificate
    Posted Aug 27, 2021 02:19 AM
    What platform are you doing this on?  I know windows can sometime do silly things with text files like adding hidden characters such as line breaks etc.
    The process you describe is pretty much how I do it and it works fine for me.
    Michael Clarke (Aruba)
  • 3.  RE: Replacing instant cluster https certificate
    Posted Aug 27, 2021 03:46 AM
    Hi Michael
    its macOS
    but just tried it in firefox on win 10 and same result .. and safari on macOS
    you start off by getting the normal view without the installed cert details but then it all just vanishes.
    Although its a blank page, view web page source gives, so its browser independent
  • 4.  RE: Replacing instant cluster https certificate
    Posted Aug 27, 2021 07:32 AM
    It seems that you can download the certificate from a tftp server from the CLI: https://www.arubanetworks.com/techdocs/Instant_83_WebHelp/Content/Instant_UG/Authentication/Certificates.htm (you may need to scroll to the right to see all the options)
    What may work as well, is to try and upload the certificate ad captive portal certificate first, until you get the certificate import right, as that upload will not affect your WebUI.
    Did you check the resulting pem file? Can you make sure that you don't miss any newlines between the certificates/key? And that the file ends with a newline as well? PEM files are normal text files, so you can use any editor to view/edit them. Check this article on how the file should look like.
    If all looks good, you may also try to use the decrypted version of your key (if you have it encrypted). Apparently, not all types of key encryption are supported by Instant.
  • 5.  RE: Replacing instant cluster https certificate
    Posted Aug 27, 2021 08:34 AM
    Many thanks for this Herman.
    The cert is a letsencrypt cert that I use.
    Something to do tonight
    Still think the guy shouldn’t blank out of you
    Rgds
    Alex
  • 6.  RE: Replacing instant cluster https certificate
    Posted Aug 27, 2021 11:19 AM
    Well
    found the clear cert command and tried
    clear-cert cp
    but get the response
    only can execute with no cert assignment
    Then checked my concatenated cert/ca/key pen file and yup there was a return missing off the end of it
    So …
    Tried
    copy tftp 192.168.2.4 arubavc-instant.pem cpserver cert fred format pem
    % Parse error
  • 7.  RE: Replacing instant cluster https certificate
    Posted Aug 27, 2021 11:40 AM
    o.k so a sh tech-aupport shows that me new cert is actually on the instant AP …its just not been assigned to anything
    so if i can find the commands to associate my cert with the userinerface/captive portal etc i should be o.k
  • 8.  RE: Replacing instant cluster https certificate
    Posted Aug 28, 2021 05:00 AM
    Looks like it is 'wlan cert-assignment-profile'.  https://www.arubanetworks.com/techdocs/CLI-Bank/Content/instant/wlan%20cert-assignment-profile.htm?Highlight=cert-assignment
  • 9.  RE: Replacing instant cluster https certificate
    Posted Sep 02, 2021 07:03 AM
    Many thanks Michael
    and that worked. I’ve assigned my new lets encrypt cert to UI and captive portal. and can now log in to the VC without firefox bleats about expired certs. However, from the GUI still get a blank screen when I go to maint/certs but now I know what to do from theCLI I can get round that
    Rgds
    Alex
  • 10.  RE: Replacing instant cluster https certificate
    Posted Oct 26, 2021 10:25 AM
    How did you associate the domain you selected on the Cert, with a domain on the AP?  My default is, https://securelogin.arubanetworks.com
    Christopher
  • 11.  RE: Replacing instant cluster https certificate
    Posted Oct 29, 2021 10:22 AM
    Please open a new discussion. This does not match the existing discussion, and it is unclear what you try to do. You should not use securelogin.arubanetworks.com, but your own certificate.
