Replay counter error message
This thread has been viewed 42 times
  • 1.  Replay counter error message
    Posted May 02, 2012 02:09 PM
    What doe the following error message mean?
    authmgr 132093>  <ERRS> |authmgr|  WPA2 Key message 2 from Station 00:90:7a:05:96:3e 00:1a:1e:59:ce:83 21.4.24 did not match the replay counter 02 vs 01
    authmgr 132093>  <ERRS> |authmgr|  WPA2 Key message 2 from Station 00:90:7a:04:b8:34 00:1a:1e:59:e3:03 21.4.15 did not match the replay counter 02 vs 01
  • 2.  RE: Replay counter error message
  • 3.  RE: Replay counter error message
    Posted Jun 01, 2012 10:46 AM
    Increasing that setting to the max 5000ms did not fix it for me. Continuing to investigate. Curious if anyone else either solved or still is receiving these messages in the logs.
  • 4.  RE: Replay counter error message
    Posted Jul 06, 2012 10:09 AM
    Did you find a solution to this? I have one AP in Paris that is having this issue and from the client side they just drop connectivity.
    Lirria
  • 5.  RE: Replay counter error message
    Posted Jul 09, 2012 07:36 AM
    Unfortunately no I have not found a workaround or other solution.
  • 6.  RE: Replay counter error message
    Posted Jul 09, 2012 10:04 AM
    No worries -
    From the bit that I have worked on this I found that changing the Interval between WPA/WPA2 key messages to be 800ms actually reduced the number of errors and stabilized the connection a good bit - still having other issues but that seemed to have helped. Still having other issues with that ap but I just checked the logs and no new replay messages on it.
    Lirria
  • 7.  RE: Replay counter error message
    Posted Jul 10, 2012 08:06 AM
    That's quite strange that decreasing the timer below the default of 1000ms would lessen the timeout issue. Wondering what Aruba will find for a solution to this issue.
  • 8.  RE: Replay counter error message
    Posted Jul 10, 2012 08:18 AM
    Istong,
    The replay counter message error is a symptom of a possible issues and does not necessarily indicate one specifically.  These problems can range from the occasional message to systemic connection issues or a man in the middle attack.  The best way to get to the bottom of YOUR issue is to open a TAC case.
    The presence of the message itself is not necessarily a problem to be solved.
  • 9.  RE: Replay counter error message
    Posted Jun 11, 2014 12:24 AM
    if there are too much of this log.
    Jun 10 12:09:24  authmgr[2001]: <132093> <ERRS> |authmgr|  WPA2 Key message 4 from Station 7c:7a:91:59:8f:e4 d8:c7:c8:4e:4a:f1 d8:c7:c8:cc:e4:ae did not match the replay counter 04 vs 05
    Does it point to loss of frames or packets to the client?
  • 10.  RE: Replay counter error message
    Posted Jun 11, 2014 05:19 AM
    This is from a search of the knowledgebase:  https://arubanetworkskb.secure.force.com/pkb/articles/Troubleshooting/R-450
  • 11.  RE: Replay counter error message
    Posted Dec 16, 2014 11:54 AM
    I am running seven instant swarms and am seeing the same error message:  WPA2 key message from station (MAC) did not match the replay counter.  I do not see anywhere in Instant GUI or CLI to edit the retransmission setting.
  • 12.  RE: Replay counter error message
    Posted Dec 01, 2017 01:51 PM
    Hello. We are facing connectivity problem for those VAP in bridge mode. The client connect but can not get IP address from DHCP. After rebooting the AP, it start to work. While searching for logs, i found many of this message: msg WPA2 Key Message.
    Any ideas? I found this post with a Solved tag.
    Regards
