Report advice
  • 1.  Report advice
    Posted Nov 04, 2013 05:57 PM
    I am trying to generate reports that will tell me in which areas i would benefit from adding WAPs due to density or just high usage for the number of clients. Anybody know a good way to set this up?
  • 2.  RE: Report advice
    Posted Nov 04, 2013 08:03 PM
    Two methods I would suggest:
    1) Look at RF Capacity Dashboard if you are running Airwave 7.7
    2) Set up 'capacity planning' report under reports.
    Raw # of clients isn't the complete measurement you will want to use as your metric to upgrade/evergreen/refresh an area... utilization is key to monitor as well.
    JF
  • 3.  RE: Report advice
    Posted Nov 05, 2013 09:13 AM
    Another report that would help is the RF Health report.  Using that along side the client health overlay in VRF can tell you about the current client experience.
