last person joined: 4 hours ago
Request HTTPS certificate to CA
  • 1.  Request HTTPS certificate to CA
    Posted 2 hours ago
    Hi community,
    I am completely new in ClearPass certificates. My visitors now get the warning message about certificate when they log in with captive portal. I realized the HTTPS certficate has expired some days ago.
    It is a certificate from a public CA. How can I get this certificate renewed? Directly contacting the CA? Or creating a CSR in CPPM? Many thanks.
    Julian
  • 2.  RE: Request HTTPS certificate to CA
    Posted 2 hours ago
    Yes, create a new CSR and using that get the certificate from your public ca. make sure to use the same SAN filed identical to the existing certificate
    it seems that you are using wildcard certificate, if it is a wildcard no need to generate CSR. download the PKCS12 certificate bundle from the Digicert portal and import it to the ClearPass.
    Harendra
    ACEX165
