Wired Intelligent Edge
Requirements for a MAD switch
  • 1.  Requirements for a MAD switch
    Posted Mar 20, 2017 06:22 PM
    Hi All,
    I have been reading VSF documentation for 5412R switches. It says to avoid split fabric issues in case VSF link goes down, it is recommended to have a third MAD switch and enable Multi Active Detection (MAD) on theVSF fabric.
    My question is does MAD switch needs to be an Aruba/HPE switch or it can be any switch that supports LACP/LLDP?
  • 2.  RE: Requirements for a MAD switch
    Posted Mar 21, 2017 08:48 AM
    For LLDP-MAD the following must be supported by the neighbor switch:
    - IP-address reachable from VSF
    - LLDP
    - SNMPv2
    - LACP
    VSF system performs a number of checks to verify if all requirements have been met. You can verfify with "show vsf lldp-mad parameters" the "MAD readiness status".
    => therefore there is no need for an Aruba/HPE switch if the above is supported.
  • 3.  RE: Requirements for a MAD switch
    Posted Mar 21, 2017 06:12 PM
    Thanks. Also found it in the documentation later on.
