Network Management
Reset Airwave Root Password via CLI
  • 1.  Reset Airwave Root Password via CLI
    Posted Mar 18, 2015 08:11 PM
    Is it possible to reset the Root Password for Airwave via CLI?
    I found the following link on the boards which references the steps if password is unknown. What if the password is known. Is there another process to reset via CLI?
    http://community.arubanetworks.com/t5/AirWave-and-Network-Management/Resetting-Airwave-Root-Password/td-p/9039
  • 2.  RE: Reset Airwave Root Password via CLI
    Posted Mar 19, 2015 10:38 AM
    If the password is known, you can simply login as the root user and then do:
    # passwd root
    This will prompt you for the existing password and then twice for the new password.
  • 3.  RE: Reset Airwave Root Password via CLI
    Posted Apr 09, 2015 05:44 PM
    Thanks Rob for the response. Your instruction was perfect.
    I was able to successfully reset the root password.
