  • 1.  reset an AP to factory default via the controller?
    Posted Dec 13, 2016 12:31 PM
    Hi - Are there other options other than consoling directly into an AP225 to purge and factory reset the device? Example:  Have a wap 225 at a remote location that would occasionally go up and down.  Replaced it with a spare and things are good.  Factory reset the bad wap via console and it's working fine again.
    Is it possible if a WAP is communicating, that i could somehow factory reset it from the controller (72xx series) and not have to go to the site and get console access?  We have thousands of waps, so this would save effort if it's mostly communicating and having occasional issues that a factory reset "across the network" rather than direct console would be wonderful.  Granted it doesn't happen very often but would be a nice options for a first step remotely kind of a thing?
    Thank you
    #AP225
  • 2.  RE: reset an AP to factory default via the controller?
    Posted Dec 13, 2016 12:32 PM
    There is not a way via the controller to do that.
  • 3.  RE: reset an AP to factory default via the controller?
    Posted Dec 13, 2016 01:32 PM
    Thank you for the confirmation.
    Where can I submit a feature request for this type of thing?
  • 4.  RE: reset an AP to factory default via the controller?
