Reset Captive Portal Admin Login
  • 1.  Reset Captive Portal Admin Login
    Posted Jun 07, 2018 05:39 PM
    my admin login to the captive Portal (Clearpass Guest) does not work anymore. The last time I used it is about half a year ago. A user login as  receptionist ist still working but I have to change some config items.
    I did not find a possibility to change the password via cli and the Policy Manager admin login does not work. Is there any other possibility to reset the password?
    Thanks an best regards
    Christian
  • 2.  RE: Reset Captive Portal Admin Login
    Posted Jun 07, 2018 06:11 PM
    Can you login to Policy Manager and Click the link for ClearPass Guest?
  • 3.  RE: Reset Captive Portal Admin Login
  • 4.  RE: Reset Captive Portal Admin Login
    Posted Jun 08, 2018 03:07 AM
    Hi Tim,
    thanks for your answer.
    I changed the appadmin password months ago away from the default password und login to Clearpass Policy Manager works. But I can‘t login to guest-portal. Maybe I did not understand the concept of login. Where can I administrate the guest portal? So that there is only a standard user login to the guest portal?
    Best regards
    Christian
  • 5.  RE: Reset Captive Portal Admin Login
    Posted Jun 08, 2018 03:26 AM
    Log in to Policy Manager and then click the Guest link on the dashboard.
