Wired Intelligent Edge
last person joined: 9 hours ago
Reset of a config on a specific interface on 5400
This thread has been viewed 37 times
  • 1.  Reset of a config on a specific interface on 5400
    Posted Jun 13, 2018 03:43 AM
    Do ´procurve have a easy way to reste config on a specific interface to deafult?
  • 2.  RE: Reset of a config on a specific interface on 5400
    Posted Jun 26, 2018 07:49 AM
    I'm not aware of any command to reset an interface to the default configuration. I always go into the interface level and either no <CMD> or set value to default.
  • 3.  RE: Reset of a config on a specific interface on 5400
    Posted Jun 26, 2018 08:23 AM
    Hi Dobias,
    Same here.  A 'default this' command from Comware could and would be nice.
    But with ClearPass (colorless ports) and automation the time of old school CLI config is slowly 'dying'.
  • 4.  RE: Reset of a config on a specific interface on 5400
    Posted Jul 02, 2018 01:06 AM
    There is no command in Aruba or Provision OS switches to set the port to default settings.
    The best way to check the configuration on a particular port and delete it would be "show running-config interface X".
    It will give the detail configuration about that port.
    Then you can remove desired configuration by enter "no" before any command you dont want.
    But these "no" commands needs to be run inside the interface context.
    I hope this information is helpful.
    If you like my posts, kudo's are welcome. If it solves your problem, please click 'Accept as Solution
    Kashif Khan
  • 5.  RE: Reset of a config on a specific interface on 5400
    Posted Jan 09, 2023 07:04 AM
    I came acrros this: these these on comware7:
    If you issue on an interface (like "interface Ten-GigabitEthernet 1/1/20")  the command "default"  you will get:
    This command will restore the default settings. Continue? [Y/N]:
  • 6.  RE: Reset of a config on a specific interface on 5400
    Posted Jan 10, 2023 02:24 AM
    Hi
    Keep in mind your VLAN configuration on the 5400 does not show up under the interface config.
    show vlan ports XX detail to get tagged and untagget VLAN on the port.
    Arne Opdal
  • 7.  RE: Reset of a config on a specific interface on 5400
    Posted Jan 13, 2023 02:09 AM
    This trick may help:
    1. create a trunk with just the port in question "trunk nn trk99"
    2. delete the trunk "no trk99"
    3. this will clear most settings and put the port back to close to default.
    You will need to check with "show run int nn" - there were some more obscure items that did not get reset with this method.
    Richard Litchfield
    Airheads MVP 2020, 2021, 2022
