RESET THE CONTROLLER (7210) AS FACTORY DEFAULT/PASSWORD RECOVERY
This thread has been viewed 127 times
  • 1.  RESET THE CONTROLLER (7210) AS FACTORY DEFAULT/PASSWORD RECOVERY
    Posted May 03, 2019 05:13 PM
    Dear All,
    We are in a new installation. unfortunately we typed minimal setup while booting the controller first time. Now can't do any thing.
    Getting the message as belowe when trying to recover the password and not able reset to factory default. Any threat please?
    User: password
    Password: *********
    (Aruba7205) >en
    Password:******
    (Aruba7205) #configure t
    Enter Configuration commands, one per line. End with CNTL/Z
    (Aruba7205) (config) #mgmt-user admin root
    Password:*********
    Re-Type password:*********
    Error : Non-Compliant to Mgmt Password Policy
    Internal error occurred, Password validation failed
    (Aruba7205) #show aaa password-policy mgmt
    You do not have permission to execute this show command show aaa password-policy mgmt
    (Aruba7205) #
    (Aruba7205) #wr erace
    You do not have permission to execute this command
    (Aruba7205) #
  • 2.  RE: RESET THE CONTROLLER (7210) AS FACTORY DEFAULT/PASSWORD RECOVERY
    MVP
    Posted May 03, 2019 07:04 PM
    Password:*********
    Did you try resetting to a password that does match the default password policy?  Aruba123! for example should work.
    In password recovery mode that is all you can do. So reset the passwd and then log in with the new credentials to do the factory reset.
  • 3.  RE: RESET THE CONTROLLER (7210) AS FACTORY DEFAULT/PASSWORD RECOVERY
    Posted May 04, 2019 03:14 PM
    Issue fixed;
    • perform a boot break from the console port at 'Hit ctrl+X to stop autoboot:'
         cpboot>
    • change the config file environment variable
         setenv cfgfile default1.cfg
         saveenv
    • issue the 'reset' command
    • reconfigure the device with the initial setup dialog (full-seup), system will reboot when complete
    • perform a boot break at 'Hit ctrl+X to stop autoboot:'
    • unset the config file environment variable
         setenv cfgfile
         saveenv
    • issue the 'reboot' command
    • login to device from console when prompted
    • issue 'write mem' command
  • 4.  RE: RESET THE CONTROLLER (7210) AS FACTORY DEFAULT/PASSWORD RECOVERY
    Posted Nov 19, 2019 05:48 PM
    Not work i got cpxload# how can I do ?
    Thank you,
  • 5.  RE: RESET THE CONTROLLER (7210) AS FACTORY DEFAULT/PASSWORD RECOVERY
    Posted Jan 07, 2020 09:24 AM
    There are two times to break the boot process.  Wait for the second time after cpboot starts to load. Then ctrl + x and you should be at the cpboot prompt.
