So, simple question.
I just want to reset to factory default an Access Point provisioned and working fine in my controller. Is there any way of remotely reset to factory default an Access Point?
You can also default an AP from a connection to its console port by interrupting the boot process
From the "apboot>" prompt, type purgeenv This erases all the configuration settings on the AP.
