I have an ap125 and ran the show ap debug radio-stat command.The Resets BeacQ Stuck count is at 8658. The 2.4 radio seems to be experiences problems.
I know this means the beacons are not being sent and there is possible excessive noise, but what else could this mean? Thanks
Yes, you may have a problem. The number is cumulative since the AP has been up, so there is a small chance you no longer have the problem.
What version of ArubaOS is this? You might have to contact support to get the full extent of it.
