[Resolved] AP stucks in upgrade/reboot loop
This thread has been viewed 23 times
  • 1.  [Resolved] AP stucks in upgrade/reboot loop
    Posted Feb 17, 2015 06:11 PM
    ArubaOS (MODEL: Aruba7240-US), Version 6.3.1.9
    AP Type 225
    Performed the AP privisoning using a Console cable:
    apboot> setenv group XXX
    apboot> setenv name ABC
    apboot> setenv master [IP]
    apboot> setenv server [IP]
    After connecting to the network AP stucks in a upgrade/reboot loop according to "show ap debug counters ap-name ABC" command.
    show datapath session table shows Y flags (output is attached). Does it mean a firewall ACL is blocking the connection?
    #AP225
  • 2.  RE: [Resolved] AP stucks in upgrade/reboot loop
    Posted Feb 17, 2015 07:39 PM
    On the controller's commandline type "show log system 50" and see if you see anything about the access point.
  • 3.  RE: [Resolved] AP stucks in upgrade/reboot loop
    Posted Feb 17, 2015 07:44 PM
    Thanks Colin.
    I just resolved the issue. I believe it was the ACL on our core switches. The following cheat sheet was really helpful with troubleshooting:
    http://community.arubanetworks.com/aruba/attachments/aruba/84/106/1/Troubleshooting+Cheat+Sheet-.pdf
    Regards
