Comware
last person joined: 7 hours ago
[RESOLVED] automatic Voice VLAN and QoS
  • 1.  [RESOLVED] automatic Voice VLAN and QoS
    Posted Feb 20, 2017 05:06 AM
    Hello all
    I have an issue configuring QoS on voice vlan.
    I did the following config :
     lldp global enable
     voice-vlan track lldp
    vlan 31
     name ToIP
     description ToIP
    interface GigabitEthernet1/0/17
     port link-type trunk
     port trunk permit vlan 1 10
     port trunk pvid vlan 10
     voice-vlan qos 5 46
     voice-vlan 31 enable
     stp edged-port
     poe enable
    interface GigabitEthernet1/0/19
     port trunk permit vlan 1 10 31
     qos trust dscp
    IP phone is on port 1/0/17 and 1/0/19 is an uplink (trunk)
    I expected to have vlan 31 outbound frames on int g1/0/19 being correctly vlan tagged and marked at L2 and L3.
    When I capture what's in and out of 1/0/19, I see the phone frames correctly tagged as vlan 31, but no CoS or DSCP are marked (all at 0)
    Here are the things I verified :
    [TEST]dis voice state
     Current voice VLANs: 1
     Voice VLAN security mode: Security
     Voice VLAN aging time: 1440 minutes
     Voice VLAN enabled ports and their modes:
     Port                        VLAN        Mode        CoS        DSCP
     GE1/0/17                    31          AUTO        5          46
    [TEST]dis mac-addr vlan 31
    MAC Address      VLAN ID    State            Port/NickName            Aging
    0080-9f91-cb09   31         VOICE-VLAN       GE1/0/17                 Y
    [TEST]dis mac-addr int g1/0/17
    0019-b97c-dcf2   10         Learned          GE1/0/17                 Y
    [TEST]dis vlan 31
     VLAN ID: 31
     VLAN type: Static
     Route interface: Configured
     IPv4 address: 192.168.3.1
     IPv4 subnet mask: 255.255.255.0
     Description: ToIP
     Tagged ports:
        GigabitEthernet1/0/17         GigabitEthernet1/0/19
     Untagged ports: None
    My question is : do I need to set a QoS policy ? I expected the automatic voice vlan config to do all the QoS stuff without additionnal config steps...
    Have a nice day.
    (on HPE 5130 EI "comware" switch)
    I finally found the solution (with the help of my co-worker) : you MUST create a OUI reference for the phone model.
    voice-vlan mac-address mac-address mask oui-mask [ description text ]
    Without this, the switch will not consider incoming frames as "voice", even if LLDP has told the phone to put them in the right VLAN.
    So, LLDP does NOT insert OUI records in the table, it just tells the phone that there is a voice vlan and it's number.
    #Voice
    #QOS
    #VLAN
    #comware
