Developer
REST API for uptime ?
This thread has been viewed 52 times
  • 1.  REST API for uptime ?
    Posted Feb 28, 2022 12:56 AM
    Hi there.
    Trting to get system uptime of Aruba2930M using REST API with no successs.
    /rest/v4/system/status/switch
    /rest/v4/system/status/global_info
    both of them gives no information about it.
    Any ideas?
    And where can I find the full API list?
    BTW:
    what's going on with the SSH Exec limitaions on Aruba?
    Why cant I go with simple $ssh->exec like in Cisco and we
    need a full SSH emulation to get into Arubs switch?
    This is really annoying.
    Isaac Chn
  • 2.  RE: REST API for uptime ?
    Posted Mar 09, 2022 01:54 PM
    Hi Isaac!
    I'm looking into this request and will update shortly!​
    Tiffany Chiapuzio-Wong
  • 3.  RE: REST API for uptime ?
    MVP GURU
    Posted Mar 31, 2022 03:34 AM
    Hi Isaac,
    For full API, you can look the ASP portal, there is a zip with all Info
    PowerArubaCL: Powershell Module to use Aruba Central
    ACEP / ACMX #107 / ACDX #1281
