Developer
Rest Api - "is_port_enabled" variable from "/ports" URI Problem
  • 1.  Rest Api - "is_port_enabled" variable from "/ports" URI Problem
    Posted Feb 14, 2020 06:40 AM
    I need the help of an aruba Rest Api dev.
    Could you tell me if the value stored in "is_port_enabled" when you call the REST URI "/ports" should indicate the administrative state (enabled/disabled) of a port even if it's a manual "change" or an auto "change" (BPDU protection for example) ?
    In my test, it only get the manual change.
    The web console display and the "show interfaces brief" command are fine.
    I'm using stacked 2930F (x3) with firmware version WC.16.10.0002.
    Thanks.
  • 2.  RE: Rest Api - "is_port_enabled" variable from "/ports" URI Problem
    Posted Feb 24, 2020 03:41 PM
    According to one of our REST API developers:
    Yes.  You are correct “is_port_enabled”  always reflects the administrative change(interface enable/disable) only.
    By default “is_port_enabled”  is ‘true’ for all the ports in the system.
    Derek
  • 3.  RE: Rest Api - "is_port_enabled" variable from "/ports" URI Problem
    Posted Feb 25, 2020 01:59 AM
    Thank you for the answer.
    So is there a URI that get the port state when it is desactivated due to security blocking (BPDU protection for example) ?
    If not, could devs add a "is_port_blocked" variable to the "/ports" URI ?
  • 4.  RE: Rest Api - "is_port_enabled" variable from "/ports" URI Problem
    MVP GURU
    Posted Feb 25, 2020 03:53 AM
    it will be better it is possible to get spanning port status... (Blocked, Forwarding, listen...) i think
