REST API JSON filter not working 6.6.2
  • 1.  REST API JSON filter not working 6.6.2
    Posted Nov 10, 2016 03:20 PM
    So I want to query for a specific device mac. In the API explorer I create a json filter '{"mac":"xx-xx-xx-xx-xx-xx"}' and this works. In the return I see the create_time field is
    "create_time": 1478804392
     So I create a filter '{"mac":"xx-xx-xx-xx-xx-xx","create_time":"1478804392"}'
    And this does not work. Is something wrong with my syntax? I should be able to do a multi-field query correct? I've also tried the query without the quotes around the time stamp but that doesn't work either.
  • 2.  RE: REST API JSON filter not working 6.6.2
    Posted Nov 10, 2016 03:25 PM
    Try removing the quotes around the create_time value:
    {"mac":"xx-xx-xx-xx-xx-xx","create_time":1478804392}
  • 3.  RE: REST API JSON filter not working 6.6.2
    Posted Nov 10, 2016 03:32 PM
    Thanks, but that didn't work either. I tried a query with only the create_time and that didn't work either. I did a query with the start_time though and that worked. It looks like it might be just something with the create_time field itself.
  • 4.  RE: REST API JSON filter not working 6.6.2
    Posted Nov 10, 2016 04:00 PM
    When you do a GET, is that attribute returned?
  • 5.  RE: REST API JSON filter not working 6.6.2
    Posted Nov 10, 2016 04:04 PM
    Yes.
  • 6.  RE: REST API JSON filter not working 6.6.2
    Posted Nov 10, 2016 07:46 PM
    Just out of curiosity, why do you need to filter on both of those attributes
    simultaneously? There can only be one account in the database with a
    particular username.
  • 7.  RE: REST API JSON filter not working 6.6.2
    Posted Nov 11, 2016 08:38 AM
    I was just testing. What I really want to do is return all devices that were created before a certain date. Like I said I did the query with just the create_time and it didn't work either. I think I'll open a TAC case and see if they can recreate the issue. I can do the date checking within my script if I need to for now.
  • 8.  RE: REST API JSON filter not working 6.6.2
    Posted Nov 22, 2016 11:03 AM
    I opened a case with the TAC and they confirmed the issue was happening on their server. They will open a ticket with engineering to look into it.
