Developer
Rest API : lldp/remote-device/{port}
  • 1.  Rest API : lldp/remote-device/{port}
    Posted Oct 06, 2023 07:08 AM
    I'm trying to retrieve the "port_type" value with "lldp/remote-device" URI on a particular port.
    But I get a "Request has failed due to non-existent resource" error when I try to specify a port outside the first member of the stack.
    Here is an example on a stack of 3 switches 2930F (Rest API v7 or 8, firmware 16.11.0013) :
    "lldp/remote-device/1/11" works fine :
     "uri":"/lldp/remote-device/1/11",
             "local_port":"1/11",
             "chassis_type":"RCT_MAC_ADDRESS",
             "chassis_id":"14 17 ea ac 5f 99",
             "port_type":"LPT_MAC_ADDRESS",
    "lldp/remote-device/3/11" does not work (and everything after 1/52).
    How does it work for you?
    Thanks for your help.
  • 2.  RE: Rest API : lldp/remote-device/{port}
    MVP GURU
    Posted Oct 24, 2023 04:20 PM
    Do you have open an issue to TAC/support ?
    PowerArubaCL: Powershell Module to use Aruba Central
    ACEP / ACMX #107 / ACDX #1281
