Developer
REST API Port Statistics 64bit
  • 1.  REST API Port Statistics 64bit
    Posted Mar 09, 2020 11:58 AM
    I am trying to query port statistics via the Aruba REST API on a 5406zl2 running firmware KB.16.10.0003.
    The API call on ../rest/v4/port-statistics/{port.id} works fine, however the returned statistics are only 32bit counters.
    Is there any way to obtain 64bit port statistics via the REST API?
    I haven't found anything regarding this in the documentation.
    Thanks!
  • 2.  RE: REST API Port Statistics 64bit
    MVP GURU
    Posted Apr 02, 2020 12:07 PM
    Sorry no idea, do you have try with v7 ? (for API call)
    I think, need to ask to TAC...
  • 3.  RE: REST API Port Statistics 64bit
    Posted Apr 03, 2020 02:11 PM
    Yes, I tried it with v7 as well, same result.
    I went back to pulling port statistics via SNMP for now (64-bit counter support is not a problem with SNMP).
    However, I would love to see this feature getting implemented in the future.
    32-bit counters overflow within a few seconds at Gigabit speeds, which means that querying those is virtually useless in many scenarios.
  • 4.  RE: REST API Port Statistics 64bit
    MVP GURU
    Posted Apr 06, 2020 03:37 AM
  • 5.  RE: REST API Port Statistics 64bit
    Posted Apr 06, 2020 05:14 AM
    thanks @alagoutte.
    I have posted the idea here:
    https://innovate.arubanetworks.com/ideas/SWITCH-I-439
    Feel free to vote if you would like to see this getting implemented.
  • 6.  RE: REST API Port Statistics 64bit
    MVP GURU
    Posted Apr 06, 2020 05:33 AM
    @0xTimT wrote:
    thanks @alagoutte.
    Done +1
