Wired Intelligent Edge
  • 1.  REST CLI commands not working on WC.16.10.0011
    Posted Dec 24, 2020 12:16 PM
    Model 2930F
    I've been upgrading and downgrading and can confirm that, at least for me, CLI commands don't work over REST on WC.16.10.0011
    They do work however on WC.16.10.0002
    I don't have any example handy, bu tI've been using python with napalm-arubaos-switch and/or aos-sw-api libraries.
  • 2.  RE: REST CLI commands not working on WC.16.10.0011
    Posted Jan 13, 2021 05:01 AM
    @egabrum Could you please share more details about the issue. If possible the results to compre with working code and non working code WC.16.10.0011
  • 3.  RE: REST CLI commands not working on WC.16.10.0011
    Posted Jan 22, 2021 07:16 AM
    @drk787Thanks for reacting.
    Here's an example of script that works perfecty on WC.16.10.0002 , but not on WC.16.10.0011 :
    import aos_sw_api
    def main():
        with aos_sw_api.Client(
            switch_ip="x.x.x.x",
            api_version=7,
            username="manager",
            password="x",
            https=False,
        ) as client:
            client.cookie
            res = client.vlan.get_all_vlans()
            print(res)
    if __name__ == "__main__":
        main()
    Similar if I use the napalm-arubaos-switch library.
    The traceback with the script above is:
    Traceback (most recent call last):
      File "U:\dev\aruba\rest_bug.py", line 30, in <module>
        main()
      File "U:\dev\aruba\rest_bug.py", line 10, in main
      File "C:\Users\user\.virtualenvs\aruba-Fs4htifT\lib\site-packages\aos_sw_api\_client.py", line 104, in __enter__
        self.auth.login(cookie=self.cookie)
      File "C:\Users\user\.virtualenvs\aruba-Fs4htifT\lib\site-packages\aos_sw_api\auth\_auth.py", line 34, in login
        r = self._session.post(url=self._auth_base_url, json=self._user_data)
      File "C:\Users\user\.virtualenvs\aruba-Fs4htifT\lib\site-packages\httpx\_client.py", line 824, in post
        return self.request(
      File "C:\Users\user\.virtualenvs\aruba-Fs4htifT\lib\site-packages\httpx\_client.py", line 600, in request
        return self.send(
      File "C:\Users\user\.virtualenvs\aruba-Fs4htifT\lib\site-packages\httpx\_client.py", line 620, in send
        response = self.send_handling_redirects(
      File "C:\Users\user\.virtualenvs\aruba-Fs4htifT\lib\site-packages\httpx\_client.py", line 647, in send_handling_redirects
        response = self.send_handling_auth(
      File "C:\Users\user\.virtualenvs\aruba-Fs4htifT\lib\site-packages\httpx\_client.py", line 684, in send_handling_auth
        response = self.send_single_request(request, timeout)
      File "C:\Users\user\.virtualenvs\aruba-Fs4htifT\lib\site-packages\httpx\_client.py", line 714, in send_single_request
        ) = transport.request(
      File "C:\Users\user\.virtualenvs\aruba-Fs4htifT\lib\site-packages\httpcore\_sync\connection_pool.py", line 152, in request
        response = connection.request(
      File "C:\Users\user\.virtualenvs\aruba-Fs4htifT\lib\site-packages\httpcore\_sync\connection.py", line 78, in request
        return self.connection.request(method, url, headers, stream, timeout)
      File "C:\Users\user\.virtualenvs\aruba-Fs4htifT\lib\site-packages\httpcore\_sync\http11.py", line 62, in request
        ) = self._receive_response(timeout)
      File "C:\Users\user\.virtualenvs\aruba-Fs4htifT\lib\site-packages\httpcore\_sync\http11.py", line 115, in _receive_response
        event = self._receive_event(timeout)
      File "C:\Users\user\.virtualenvs\aruba-Fs4htifT\lib\site-packages\httpcore\_sync\http11.py", line 142, in _receive_event
        event = self.h11_state.next_event()
      File "c:\program files\python39\lib\contextlib.py", line 135, in __exit__
        self.gen.throw(type, value, traceback)
      File "C:\Users\user\.virtualenvs\aruba-Fs4htifT\lib\site-packages\httpcore\_exceptions.py", line 12, in map_exceptions
        raise to_exc(exc) from None
    httpcore._exceptions.ProtocolError: can't handle event type ConnectionClosed when role=SERVER and state=SEND_RESPONSE
    Maybe this is an issue on the Python side, not on the AOS side but what could have changed on AOS to break this?
  • 4.  RE: REST CLI commands not working on WC.16.10.0011
    Posted Jan 23, 2021 03:49 AM
    WC.16.10.0011 works with curl:
    POST /rest/v7/login-sessions HTTP/1.1
    Host: x.x.x.x
    User-Agent: curl/7.55.1
    Accept: */*
    Content-Length: 46
    Content-Type: application/x-www-form-urlencoded
    {"userName":"manager", "password":"x"}
    But not with Python (I have tried httpx and requests):
    Host: x.x.x.x
    Accept: */*
    Accept-Encoding: gzip, deflate
    Connection: keep-alive
    User-Agent: python-httpx/0.16.1
    Content-Length: 48
    Content-Type: application/json
    {"userName": "manager", "password": "x"}
    No response, the switch just shuts the connection.
    I'm reading and researching as much as I can. But I'm flabbergastered as to why this version would behave differently. I read the changelog and can't find anything that seems relevant.
    Can somebody look into this? I've been chasing this for long now.
    #rest
    #Python
    #API
  • 5.  RE: REST CLI commands not working on WC.16.10.0011
    Posted Jan 25, 2021 08:54 PM
    @egabrum  I would suggest to open a support case to investigate further on the differences between the codes.
    Also can you try enabling the debugging and see the evetns during non-peak hours.
    debug destination session (to display the events on the terminal)
    debug rest-interface (debuggin the rest api)
    Once done, stop the debugging using  'no debug all'
  • 6.  RE: REST CLI commands not working on WC.16.10.0011
    Posted Jan 28, 2021 06:16 PM
    Thank you drk787
    It was a bug in WC.16.10.0011 , fixed in WC.16.10.0012
