Hello EveryOne.... :smileyhappy:
How can I restart any AP from Master ? (Via CLI <SSH>)
If I type: "Show ap databse long", I want to restart any AP from list there.
Thank you very much.
@davinal12
Thank you Victor for your answer.
It works !!! :D
Hi Victor.
How can I restart master controller from CLI (in master controller) ? :smileyindifferent:
reload command
Make sure you save your config before you do
Viktor,
Is there any way to restart the APs from GUI?
Yes:
Hi, Would this command work with HP MSM720, I want to reset the connected APs from the controller with CLI
Once I have the complete command, I want to create a script
thanks
