restarting webservice
This thread has been viewed 39 times
  • 1.  restarting webservice
    MVP
    Posted Jul 28, 2014 09:02 AM
    Is there a way to restart the webserver service of an Aruba controller?
    After installing a new server cert the gui does not come back up and also the redirect from http to https isn't happening.
    I'd rather not reboot the entire controller as there's quite q few users connected.
    No support on the box so no TAC available.
  • 2.  RE: restarting webservice
    Posted Jul 28, 2014 11:19 AM
    Can you try and put the default certificate back in place:
    web-server no switch-cert
    web-server switch-cert Default
  • 3.  RE: restarting webservice
    Posted Jul 28, 2014 11:22 AM
    If that does not work, you can try to restart:
    process restart httpd
  • 4.  RE: restarting webservice
    MVP
    Posted Jul 28, 2014 12:06 PM
    ended up reloading before I saw this, then imported the im-ca and root-ca and tried again selecting the new server-cert and all is good again.
    Thanks for the info though!
