Restore a configuration files on an Aruba controller
This thread has been viewed 39 times
  • 1.  Restore a configuration files on an Aruba controller
    Posted Mar 06, 2013 06:53 AM
    I try to restore a configuration file on a controller using FTP, TFTP or SCP. Always the same errors, the controller can't copy the file or it is directly connected to the server.
    Any idea.
    Thankx guys
  • 2.  RE: Restore a configuration files on an Aruba controller
    Posted Mar 06, 2013 06:59 AM
    Restoring a configuration is a three step process:
    - Copy the file to the controller
    - Set the boot config to that file
    - Reboot.
  • 3.  RE: Restore a configuration files on an Aruba controller
    Posted Mar 06, 2013 07:02 AM
    I know this. I said that i have a problem with COPYING the file on the controller. The server (TFTP, FTP, SCP) is directly connected to the controller. However it doesn't copy it saying that there a problem of timeout!!!
    Thankx
  • 4.  RE: Restore a configuration files on an Aruba controller
    Posted Mar 06, 2013 07:04 AM
    Ok.  Well we have to apply the rules of networking, then:
    Can the controller and the SCP/TFTP server ping each other?
  • 5.  RE: Restore a configuration files on an Aruba controller
    Posted Mar 06, 2013 07:13 AM
    Yes ping Ok
    HTTP OK
    Thankx.
  • 6.  RE: Restore a configuration files on an Aruba controller
    Posted Mar 06, 2013 07:20 AM
    I hate to say it, but this is a networking issue.  If you do not have your client running or you have your firewall on your host/laptop it is not going to work.  If you have already established that the controller and the host can ping each other, it is a networking issue, NOT an Aruba issue...
  • 7.  RE: Restore a configuration files on an Aruba controller
    Posted Mar 06, 2013 07:24 AM
    It is strange. Because if it is really a network issue at this moment they can't ping each other !!! I looked for the firewall hosted in the server it is already stopped !!
    Thank you anyway.
  • 8.  RE: Restore a configuration files on an Aruba controller
    Posted Mar 06, 2013 07:30 AM
    Have you ever used TFTP on that server before?  Can you use the "netstat -an" command on the server to see if there is traffic coming from the controller?
  • 9.  RE: Restore a configuration files on an Aruba controller
    Posted Mar 06, 2013 07:34 AM
    Yes i used this TFTP server Before. No there are no TFTP traffic coming from the controller. Does it may depend of the firewall on the controller it self?
    Thankx
  • 10.  RE: Restore a configuration files on an Aruba controller
    Posted Mar 06, 2013 07:35 AM
    By default there is no firewall stopping traffic to and from the controller.
    Is the server and the controller on the same subnet?  Is there a device that could be blocking the traffic between them?
  • 11.  RE: Restore a configuration files on an Aruba controller
    Posted Mar 06, 2013 07:40 AM
    The controller and the server are in the same Subnet. The server is directly connected to the controller. It is a spare controller. Our production one is down. So i get the backup and i want to put it on the controller. Every thing is ok except FTP, TFTP and SCP trafic are blocked by who i don't know. I disabled the firewall and the Anti-virus because i though it may come from them. But i still have the same problem.
    Thank you
  • 12.  RE: Restore a configuration files on an Aruba controller
    Posted Mar 06, 2013 08:10 AM
    is it not possible to douwnload a file directly from a PC to the controller via HTTP?
  • 13.  RE: Restore a configuration files on an Aruba controller
    Posted Mar 06, 2013 08:24 AM
    No, you cannot upload it via HTTP.
    Other thoughts:
    • Can you post the config of the port you are plugged into?
    • What TFTP server are you using on your system?
    • Can you confirm that TFTP is listening on TCP 69?   netstat -an
    • Can you try another port on the controller?
  • 14.  RE: Restore a configuration files on an Aruba controller
    Posted Mar 06, 2013 09:20 AM
    - I am connected to the port 1: It is a port trunk with native Vlan 1 : 10.1.10.0/24
    - I changed the port. Same problem.
    -Tftp server ! Tftpd64 on windows 7 prof.
    Thnakx
  • 15.  RE: Restore a configuration files on an Aruba controller
    Posted Mar 24, 2023 10:38 AM
    any luck? is it done ??
  • 16.  RE: Restore a configuration files on an Aruba controller
    Posted Mar 25, 2023 09:56 AM
    Hi, just to not leave anything out. Is the port on the controller configured as trusted? I ask this because you say is directly connected.
    If the port configuration says untrusted change it to trusted and give it a try.
    I hope this helps.
