Restore a CP-SW-EVAL configuration file to CP-VA-500
  • 1.  Restore a CP-SW-EVAL configuration file to CP-VA-500
    Posted Nov 30, 2016 06:10 AM
    Hi
    can I restore a “CP-SW-EVAL” configuration file to “CP-VA-500” device
  • 2.  RE: Restore a CP-SW-EVAL configuration file to CP-VA-500
    Posted Nov 30, 2016 07:21 AM
    Yes, you can. The config backup is not dependent on the appliance type/size.
  • 3.  RE: Restore a CP-SW-EVAL configuration file to CP-VA-500
    Posted Nov 30, 2016 11:45 AM
    I want to restore this file to a cluster, so do I have to restore it to the publisher and then create the cluster (join the subscriber), or I have to create the cluster first and then restore the file?
  • 4.  RE: Restore a CP-SW-EVAL configuration file to CP-VA-500
    Posted Nov 30, 2016 11:47 AM
    You should restore to the publisher, then join subscribers.
