Network Management
Restore Controller / Switch config
  • 1.  Restore Controller / Switch config
    Posted Jan 25, 2017 08:41 AM
    Hi!
    I´ve read that I´m supposed to be able to restore controller or switch config from the audit page. But restore option doesn´t show in my console: Se image below. (this is for both of my controllers)
  • 2.  RE: Restore Controller / Switch config
    Posted Jan 26, 2017 07:52 AM
    Here's what you should see on Airwave 8.0.
    Are you running nightly backups as they are not appearing archived backups & configs list?
  • 3.  RE: Restore Controller / Switch config
    Posted Jan 27, 2017 08:14 AM
    I haven´t changed anything regarding backup of swtiches and controllers. Have been reading the user guide and it seems it´s configured by default ?
    The devices are in monitor mode, but that shouldn´t matter right ?
    Controller Backups and Restoration
    You can create a backup on demand by creating and collecting a flash backup from the controller. Daily backups are also created. At a minimum, there are four backup files:
     Two daily backups
     One backup from last week
     One backup from last month
    The backup saved from a firmware upgrade is automatic and requires no manual intervention. All backups can be saved or restored and are displayed on the Audit page. You can only perform a backup on a device if the firmware version of the device and the backup image are identical. After you click Restore, the device on which the restoration is being performed automatically switches from monitor mode to maintenance mode. After you restore a backup image to a device, you must restart the controller."
