Restore IAP image
  • 1.  Restore IAP image
    Posted Jul 08, 2013 03:53 AM
    Hi!
    I had a corrupt Instant image on my IAP. It said checksum check failed when consoling it and couldn't get upgraded. It allways reverted back to the first version.
    I tried purge, clear os, reset and after that it came up as a campus AP. When I try hard reset after this it still come up as a campus AP. Is there a way to load the instant image onto this AP again?
  • 2.  RE: Restore IAP image
    Posted Jul 08, 2013 04:25 AM
    Have you tried the following :
    https://arubanetworkskb.secure.force.com/pkb/articles/HowTo/R-1417
    Do you have other IAPs in that network ?
  • 3.  RE: Restore IAP image
    Posted Jul 08, 2013 05:05 AM
    Yeah, that's what I refer to as the "hard reset". Nope this is a single IAP I use for lab.
    Best regards,
    Chris
  • 4.  RE: Restore IAP image
    Posted Jul 08, 2013 09:28 AM
    Please open a case with our TAC for troubleshooting and recovery.  Please provide them the details on how you converted to controller based SW and how you attempted to go back to IAP SW.   The problem you encountered shoud not occur.
  • 5.  RE: Restore IAP image
    Posted Jul 08, 2013 11:01 AM
    Hi Mewn,
    Please call me at 408.585.1928 with regards to this issue else provide me the case number which you had open with TAC for tracking purpose.
    Thanks & Regards,
    Sriram Subramanian
    Technical Support Engineer
    srirams@arubanetworks.com
    408.585.1928
