Network Management
restore switch configuration in AirWave
  • 1.  restore switch configuration in AirWave
    Posted Nov 06, 2019 01:44 PM
    Hi all
    how can i restore new switch configuration in airwave version 8.2.9?
    let say i have switch in airwave and the switch get fualty
    and i replace the switch and want to restore the fualty switch config
    to the replacemant switch.
    can the airwave do that ?
  • 2.  RE: restore switch configuration in AirWave
    Posted Nov 06, 2019 01:48 PM
    Yes, Avia.
    Airwave keeps the backup of the running config of the switch. once you add the new switch. you can push that old's switches configuration to the new switch from Airwave.
  • 3.  RE: restore switch configuration in AirWave
    Posted Nov 06, 2019 02:08 PM
    Hi Mohammed
    can you please guide me how  ?
  • 4.  RE: restore switch configuration in AirWave
    Posted Nov 06, 2019 06:03 PM
    Once you add the device to Airwave, in the config page of this device, you will have the running config automatically backed up. This config gets saved in the group as a template.
    Just add a new device to the same group, where you have this template, put it in manage mode, This template config will gets pushed to the new device.
  • 5.  RE: restore switch configuration in AirWave
    Posted Nov 11, 2019 09:15 AM
    Thank you!!
