Wired Intelligent Edge
Restrict access to switch - ArubaCX
This thread has been viewed 35 times
  • 1.  Restrict access to switch - ArubaCX
    Posted Aug 18, 2020 05:28 AM
    Hi
    I recently purchased 2 switches Aruba 8320 based on ArubaCX-OS
    I want to allow specific addresses to access SNMP  & SSH
    like the commands in aruba-os - 2930f for example:
    ip authorized-managers 192.168.1.10 access-method ssh
    ip authorized-managers 192.168.2.10 access-method access operator
    ip authorized-managers 192.168.2.11 access-method access manager
    I use only one VRF (the default)
    How can i do it?
    I checked this Topic:
    https://community.arubanetworks.com/t5/Wired-Intelligent-Edge-Campus/ip-authorized-managers-on-the-CX/td-p/557195
    And it does not help me because the config on control plane blocks all traffic.
  • 2.  RE: Restrict access to switch - ArubaCX
    Posted Aug 18, 2020 07:02 AM
    This way might help:
    access-list ip authorized-ACL
    10 permit tcp 192.168.1.10 any eq 22
    20 permit tcp 192.168.2.10 any eq 22
    21 permit tcp 192.168.2.10 any eq 443
    22 permit tcp 192.168.2.10 any eq 80
    23 permit udp 192.168.2.10 any eq 161
    30 permit tcp 192.168.2.11 any eq 22
    31 permit tcp 192.168.2.11 any eq 443
    32 permit tcp 192.168.2.11 any eq 80
    33 permit udp 192.168.2.11 any eq 161
    90 deny tcp any any eq 22
    91 deny tcp any any eq 443
    92 deny tcp any any eq 80
    93 deny udp any any eq 161
    100 permit any any any
    then
    apply access-list ip authorized-ACL control-plane vrf default
  • 3.  RE: Restrict access to switch - ArubaCX
    Posted Aug 19, 2020 12:14 AM
    If I have a user who wants to access other http/https, it will not block the access to other sites?
  • 4.  RE: Restrict access to switch - ArubaCX
    Posted Aug 19, 2020 04:44 AM
    No. This ACL is applied on the control-plane and not on the data-plane, so it does not impact user traffic.
  • 5.  RE: Restrict access to switch - ArubaCX
    Posted Aug 23, 2020 12:36 AM
    I config this command for checks:
    200 deny tcp any any eq 22
    300 permit any any any
    After that stations do not get an IP address from DHCP for example
    I do not know what other problem were created.
    It does not work, Is there another solution similar to Cisco "line vty"?
  • 6.  RE: Restrict access to switch - ArubaCX
    Posted Aug 24, 2020 04:37 AM
    This is strange. It should work. I would recommend to open a TAC case.
