We are using a 3200XM controller running 6.3.1.4. We've got two different SSID's both of whic using Captive portal (No Clearpass). Authentication is the internal database. Let's call one SSID, "Guest" & the other "Employee". What can I do to prevent guests from logging into the crew captive portal and vice versa? The reason we want two seperate SSID's is that we have an upstream device that restricts bandwidth out to the internet based on the VLAN.
The alternative we tried was to combine the two into one captive portal (one VLAN) & then use a different role for "guest" clients and "employee" clients. This works fine for authentication, however it does NOT allow us to restrict bandwidth like we need to. The lowest you can set a bandwidth contract is 256Kb and we need to go lower than that.
Thoughts?
