Restrict Management Access to IAP
  • 1.  Restrict Management Access to IAP
    Posted Mar 27, 2019 06:03 PM
    In my home environment I am using a management VLAN. In order to restrict access to the switch I used the "ip authorized-managers" command.
    In the same way I would like to restrict access to the Instant Access Point. Is there a similar command in ArubaOS?
    ArubaOS (MODEL: 324), Version 8.3.0.6
  • 2.  RE: Restrict Management Access to IAP
    Posted Mar 28, 2019 04:41 AM
    Are you looking for the management subnet feature?
