Restrict smartphones on a SSID based on app installed on them.
  • 1.  Restrict smartphones on a SSID based on app installed on them.
    Posted Jul 04, 2015 12:44 AM
    Hi
    I have a requirement, we would like to allow smart devices with "Alcatel-Lucent OTNS SmartApp" app alone be associated to the SSID. we would like to keep away the other smart devices out of connecting to the SSID. The laptops(windows and MAC) should be allowed to connect.
    is this possible to be achived?
  • 2.  RE: Restrict smartphones on a SSID based on app installed on them.
    Posted Jul 04, 2015 12:47 AM
    This would require both ClearPass and an MDM solution.
    Tim
  • 3.  RE: Restrict smartphones on a SSID based on app installed on them.
    Posted Jul 05, 2015 12:26 PM
    Thank you for reply. Any reference documents available for it?
  • 4.  RE: Restrict smartphones on a SSID based on app installed on them.
  • 5.  RE: Restrict smartphones on a SSID based on app installed on them.
    Posted Jul 05, 2015 12:35 PM
    What documents are you looking for?
    Tim
  • 6.  RE: Restrict smartphones on a SSID based on app installed on them.
    Posted Jul 05, 2015 11:53 PM
    Cappalli, I am fine with the controller configuration. Any sample configuration on clearpass, as how the MDM solution could be implemented, will be helpful.
  • 7.  RE: Restrict smartphones on a SSID based on app installed on them.
    Posted Jul 06, 2015 01:16 AM
    Is this possible to be implemented with just the controller and clearpass?
  • 8.  RE: Restrict smartphones on a SSID based on app installed on them.
    Posted Jul 06, 2015 03:57 PM
    no, as neither the controller nor clearpass can see which Apps are installed on the smartphone when it connects to your SSID.
    you will need a system that can look at which Apps are installed and relay that information to ClearPass. a MDM is then the way to go.
