Return attribut to IAP to display username - %{Endpoint:Username}
  • 1.  Return attribut to IAP to display username - %{Endpoint:Username}
    Posted May 26, 2021 04:22 PM
    I cannot seem to send the %{Endpoint:Username} attribute from ClearPass to my IAPs so that I can display something other than the machines hostname.
    Is there an attribute that can be returned from ClearPass like you can with controllers?  running the latest GA IAP code (8.6.0.9)
    Randy
    Randy Bobula
  • 2.  RE: Return attribut to IAP to display username - %{Endpoint:Username}
    Posted May 27, 2021 03:58 AM
    Hi
    You should use Radius Attribute "Radius:IETF User-Name (1)"
    Regards
    Piotr Filip
    ACEX#41/ACCX/ACDX/ACMX/CWNA/CWSP
  • 3.  RE: Return attribut to IAP to display username - %{Endpoint:Username}
    Posted May 27, 2021 09:14 AM
    apologies...I thought it was assumed that I am using the "IETF:RADIUS User-Name" attribute...the value I posted above is for the aforementioned return attribute...
    The attribute above correctly returns the username value in the endpoint db to physical controllers but not to IAPs...
    Randy
    Randy Bobula
