Revoking clearpass onboard certificate fails
  • 1.  Revoking clearpass onboard certificate fails
    Posted Nov 18, 2013 11:20 PM
    Hello guys,
    We are using EAP-TLS certificates (after onboarding iOS devices) for authentication. Hopefully I should use [EAP TLS with OCSP enabled] as authentication method (not just 'EAP-TLS'). I'm trying to revoke a tls-client cert in clearpass such that it's client is denied access.
    I'm mentioning an OCSP URL in Authority Info Access in clearpass onboard CA settings also. But when I try to access the network, I'm getting "Could not verify OCSP response - EAP-TLS: fatal alert by server - certificate_unknown" error. Please see the attached images.
    Could you pls guide?
    Bharani..
  • 2.  RE: Revoking clearpass onboard certificate fails
    Posted Nov 19, 2013 02:39 PM
    Is ClearPass the certificate authority or is it a subordinate CA?
    If it's the CA, view the details for [EAP TLS With OCSP Enabled].  Check this against the actual OCSP URL.  To do this, switchover to ClearPass Guest, and navigate to: Onboard > Initial Setup > Certificate Authorities.  The ClearPass CA is listed here along with the OCSP URL.  Make sure it matches the URL in your EAP TLS method.
  • 3.  RE: Revoking clearpass onboard certificate fails
    Posted Nov 19, 2013 09:26 PM
    Hello MVP,
    Thank you for your reply. Probably that should be the mistake I guess. I'll go to office and give it a try and get back to you.
    Bharani..
  • 4.  RE: Revoking clearpass onboard certificate fails
    Posted Nov 21, 2013 09:43 PM
    It has worked! The OCSP URL should be same on CPPM as well as CA settings in CPPM onboard page.
    Thank you.
    Bharani..
