RF planner
  • 1.  RF planner
    Posted Sep 27, 2012 02:36 PM
    Anybody else having uploading autocad 2013 files? Is there a RF planner update to support the 2013 autocads?
  • 2.  RE: RF planner
    Posted Apr 29, 2013 05:22 AM
    Can any one please send me a link to download the RF Planner .
    khurrammalikx@hotmail.com .
    Regards
  • 3.  RE: RF planner
    MVP
    Posted Jul 24, 2013 02:42 PM
    http://support.arubanetworks.com/DOWNLOADSOFTWARE/tabid/75/DMXModule/510/Default.aspx?EntryId=4830
    You will have to log into the support site with partner credentials and you can download the VisualRF Plan tool. I believe that is the direct link, but if that doesn't work you can follow the previous instructions.
    Thanks.
  • 4.  RE: RF planner
    Posted Aug 09, 2013 01:16 PM
    I've down loaded the RF Planner 7.7 Build 432, and I'm still getting an error when loading a ".dwg" CAD file into RF Planner.
    The error I'm getting is:
    There are irregularites with this CAD document:
    Object of class OdGiRasterImage can't be cast to OdRasterConvertPE.
    Perhaps this CAD file does not support Active Layout?
    Please refer to the 'Error' listings in the CAD Info panel for further information.
    I tried tweaking some of the "CAD Layers" in the panel to the left, however this didn't really seem to give me a clear picture, I'm able to get some information to come through, but the text is very distorted and when you zoom in, it becomes really pixelated.  The facility shows as width 375.61(ft), height 557.77(ft), you don't think this would be a file size issue, would it?
    The CAD Layers I have are:
    0
    BORDER
    DIMENTIONS
    Defpoints
    Dimensions
    Hidden
    INSULATION
    New Walls
    TEXT
    Text-H
    h-supply
    CAD Info
    FUW Version - 3.05
    File Type - DWG
    Version - 2007
    Layout - Model
    Units - Inches
    Measure - English
    Width - 4507.35
    Height - 6693.22
    Error - Object of Class
    I've attached a copy of the error.
  • 5.  RE: RF planner
    Posted Sep 06, 2013 09:48 AM
    David,
    Did you ever find a solution?  I'm having the same problem and also getting the DWGconvert.exe has stopped working error. It's getting frustrating..
  • 6.  RE: RF planner
    Posted Sep 10, 2013 07:38 AM
    I have not found a solution in the RF Planner Tool, but the work around I did as others mentioned was using a PDF file instead.  Then I  used the DWG TrueViewer (Free) program to pull dimensions off the .dwg file itself.
  • 7.  RE: RF planner
    Posted Oct 10, 2014 01:46 PM
    I have had the same problem importing AutoCad DWG files for sometime now. The workaround I found is to save the drawing as an older version of CAD. I have been saving files as 2004/LT2004 under files of type.
    I believe there is something to turn on or off in the 2013 version. I just haven't had the time to figure it out yet.
  • 8.  RE: RF planner
    Posted Oct 10, 2014 02:22 PM
    If you're having issues with importing floor plans, please open a support case and have support file a defect (including a sample floor plan file that failed to import).  We've got a few conversion defects that are being worked on, but having actual floor plans will help ensure that it works against floor plans that originate in the field.
  • 9.  RE: RF planner
    MVP
    Posted Sep 06, 2013 10:20 AM
    As a temporary work around you could take a screen shot of the floor plan and scale it using the VisualRF tool.
    As far as the CAD files error, I'm not sure why your receiving an error. I do believe that dimensions in CAD need to be 100% accurate, that may be the cause. I'm not completely sure though.
  • 10.  RE: RF planner
    Posted Sep 09, 2013 03:20 PM
    I've just have been uploading .PDF files instead..
