last person joined: 11 hours ago
RF survey - setting max power to match least capable client
  • 1.  RF survey - setting max power to match least capable client
    Posted Aug 20, 2015 12:09 PM
    I need some clarfication on iAP trasmit power to match that of the client device for a pre instal survey.
    The iAP power is set using an EIRP value and we are given a mW rating for the client device (30mW).
    I understand the calculation that goes into EIRP and that 30mW is equivelant to 15dBm. Is it as simple as setting the EIRP value to 15? Or am I missing some important math?
  • 2.  RE: RF survey - setting max power to match least capable client
    Posted Aug 20, 2015 12:11 PM
    - Setting the power to the range of your clients is a good starting point.  It is not necessarily a hard-and-fast rule.
    - You are correct on your power assumption.  You would set it to 15, yes.
