RFC3576 config question.
  • 1.  RFC3576 config question.
    Posted Nov 04, 2015 08:22 AM
    I've got a CPPM cluster that we load balance auth requests to from our mobility controllers. Am I right in assuming that I only need to configure an entry for the master publisher Ip address on the controllers as a 3576 capable server given that any CoA commands will be coming from a gui connected to the master publisher?
    What do other people do when you've got a load balanced group of clearpass servers and want to mplement CoA ?
    Rgds
    Alex
  • 2.  RE: RFC3576 config question.
    Posted Nov 04, 2015 08:24 AM
    You should add all of your ClearPass servers as authorized RFC 3576 servers on the controller.
    Tim
  • 3.  RE: RFC3576 config question.
    Posted Nov 04, 2015 08:35 AM
    Just to complicate matters, I've got eeach cppm VM set up with 2 network interfaces, the management side is set up on 144.32.128.0/23 while the data side is set up on 144.32.126.0/23. Our load balancer load balances auth-requests over the data interfaces i.e. 144.32.126.xxx
    Which set of interfaces do I use for the CoA? Data side?
    A
  • 4.  RE: RFC3576 config question.
    Posted Nov 04, 2015 09:10 AM
