Hi Guys,
I try the adhoc detection and protection, but after i set the needed checkbox (AdHoc detection, AdHoc protection) my AMs dont block the adhoc connection...I have a test adhoc network (Windows XP, DHCP server on this XP, Intel Proset wifi client application which can start the adhoc network). After the needed configuration my second laptop can connect to the adhoc...
Have someone any experience with the adhoc blocking?
Thanx
Tamas
Containing Ad-Hoc networks using typical deauth method is not very effective because some client drivers ignore the deauths in ad-hoc mode and some even change channel to avoid it. You need to turn on Tarpitting to address this. Tarpitting clients requires the RFprotect license and ArubaOS 6.x and above. Please see the pic below to see where to configure this parameter
To view events, type "show log wireless 50" to see containment events.
