RIM devices won't connect to WPA2-Enterprise network
  • 1.  RIM devices won't connect to WPA2-Enterprise network
    Posted Mar 08, 2012 10:51 AM
    This is driving me nuts.. I have a ticket open with RIM but they're taking forever. I was hoping someone here might be in the same boat:
    I seem to have extreme amounts of difficulty getting blackberries and playbooks connected to my WPA2-Enterprise PEAP/MSCHAPv2 network.
    - Other clients work fine: OS X, Windows All, iPhone, iPad, iPod etc
    - Some (read: few) blackberries work
    - all 9790 blackberries I've tried do not work
    - Multiple playbooks do not work
    Anyone experience something similar?
    Dave
  • 2.  RE: RIM devices won't connect to WPA2-Enterprise network
    Posted Mar 08, 2012 11:18 AM
    Can you do show auth-tracebuf <mac of bberry client> while you are attempting to connect one and post the results back here?
  • 3.  RE: RIM devices won't connect to WPA2-Enterprise network
    Posted Mar 08, 2012 12:11 PM
    Sure. I'll have one in my possession this afternoon and will update.
    Dave
  • 4.  RE: RIM devices won't connect to WPA2-Enterprise network
    Posted Mar 08, 2012 02:51 PM
    Here is a log with a few attempts.
    This is what radius says:
    Thu Mar 8 13:39:01 2012 : Auth: Login incorrect (TLS Alert read:fatal:unknown CA): [user1] (from client wn-wc-phy-211-a port 0 cli 806007212713)
    Thu Mar 8 13:41:39 2012 : Auth: Login incorrect (TLS Alert read:fatal:unknown CA): [user1] (from client wn-wc-phy-211-a port 0 cli 806007212713)
    Thu Mar 8 13:44:26 2012 : Auth: Login incorrect (TLS Alert read:fatal:unknown CA): [user1] (from client wn-wc-phy-211-a port 0 cli 806007212713)
    Thu Mar 8 13:47:47 2012 : Auth: Login incorrect (TLS Alert read:fatal:unknown CA): [user1] (from client wn-wc-phy-211-a port 0 cli 806007212713)
    Thu Mar 8 13:49:05 2012 : Auth: Login incorrect (TLS Alert read:fatal:unknown CA): [user1] (from client wn-wc-phy-211-a port 0 cli 806007212713)
    Thu Mar 8 13:59:43 2012 : Auth: Login incorrect (TLS Alert read:fatal:unknown CA): [user1] (from client wn-wc-phy-211-a port 0 cli 806007212713)
    Thu Mar 8 14:09:17 2012 : Auth: Login incorrect (TLS Alert read:fatal:unknown CA): [user1] (from client wn-wc-phy-211-a port 0 cli 806007212713)
    ps. .txt really should be a valid attachmet extension.
    Dave
    Attachment(s)
    zip
    auth buffer.txt.zip   1 KB 1 version
  • 5.  RE: RIM devices won't connect to WPA2-Enterprise network
    Posted Mar 08, 2012 03:12 PM
    Each RIM device comes with a client manager where you have to load the CA certificate of the WLAN in order for it to connect.  It doesn't seem to just skip or accept any CA server unless you upload it to the device.  Maybe they have evolved recently.
  • 6.  RE: RIM devices won't connect to WPA2-Enterprise network
    Posted Mar 08, 2012 03:26 PM
    Hi Colin,
    I will try to do that and report back. It seems that only newer blackberries are problematic, which is strange.
    Anyways, I will let you know how it goes.
    Dave
  • 7.  RE: RIM devices won't connect to WPA2-Enterprise network
    Posted Mar 08, 2012 03:29 PM
    @daveald wrote:
    Hi Colin,
    Dave
    Wow.  That does not make sense.  What is the "show auth-tracebuf mac <mac address of blackberry>" output?
  • 8.  RE: RIM devices won't connect to WPA2-Enterprise network
    Posted Mar 08, 2012 03:37 PM
    Hi Colin,
    There is a zip file up a few posts with a longer and properly spaced log. Here is an excerpt. This just repeats, and radius logs what I mentioned earlier...
    Mar 8 14:11:14 eap-id-req <- 80:60:07:21:27:13 d8:c7:c8:17:09:2a 6 5
    Mar 8 14:11:22 station-up * 80:60:07:21:27:13 d8:c7:c8:17:09:2a - - wpa2 aes
    Mar 8 14:11:22 eap-id-req <- 80:60:07:21:27:13 d8:c7:c8:17:09:2a 6 5
    Mar 8 14:11:22 eap-id-resp -> 80:60:07:21:27:13 d8:c7:c8:17:09:2a 6 26 user1
    Mar 8 14:11:22 rad-req -> 80:60:07:21:27:13 d8:c7:c8:17:09:2a 65532 210
    Mar 8 14:11:22 rad-resp <- 80:60:07:21:27:13 d8:c7:c8:17:09:2a/cn-aaa-mc 65532 64
    Mar 8 14:11:22 eap-req <- 80:60:07:21:27:13 d8:c7:c8:17:09:2a 7 6
    Mar 8 14:11:22 eap-resp -> 80:60:07:21:27:13 d8:c7:c8:17:09:2a 7 74
    Mar 8 14:11:22 rad-req -> 80:60:07:21:27:13 d8:c7:c8:17:09:2a/cn-aaa-mc 65521 276
    Mar 8 14:11:22 rad-resp <- 80:60:07:21:27:13 d8:c7:c8:17:09:2a/cn-aaa-mc 65521 1090
    Mar 8 14:11:22 eap-req <- 80:60:07:21:27:13 d8:c7:c8:17:09:2a 8 1024
    Mar 8 14:11:22 eap-resp -> 80:60:07:21:27:13 d8:c7:c8:17:09:2a 8 6
    Mar 8 14:11:22 rad-req -> 80:60:07:21:27:13 d8:c7:c8:17:09:2a/cn-aaa-mc 113 208
    Mar 8 14:11:22 rad-resp <- 80:60:07:21:27:13 d8:c7:c8:17:09:2a/cn-aaa-mc 113 1086
    Mar 8 14:11:22 eap-req <- 80:60:07:21:27:13 d8:c7:c8:17:09:2a 9 1020
    Mar 8 14:11:22 eap-resp -> 80:60:07:21:27:13 d8:c7:c8:17:09:2a 9 6
    Mar 8 14:11:22 rad-req -> 80:60:07:21:27:13 d8:c7:c8:17:09:2a/cn-aaa-mc 5 208
    Mar 8 14:11:22 rad-resp <- 80:60:07:21:27:13 d8:c7:c8:17:09:2a/cn-aaa-mc 5 646
    Mar 8 14:11:22 eap-req <- 80:60:07:21:27:13 d8:c7:c8:17:09:2a 10 584
    Mar 8 14:11:22 eap-resp -> 80:60:07:21:27:13 d8:c7:c8:17:09:2a 10 13
    Mar 8 14:11:22 rad-req -> 80:60:07:21:27:13 d8:c7:c8:17:09:2a/cn-aaa-mc 108 215
    Mar 8 14:11:22 rad-reject <- 80:60:07:21:27:13 d8:c7:c8:17:09:2a/cn-aaa-mc 108 44
    Mar 8 14:11:22 eap-failure <- 80:60:07:21:27:13 d8:c7:c8:17:09:2a 10 4 server rejected
    Mar 8 14:11:31 station-down * 80:60:07:21:27:13 d8:c7:c8:17:09:2a - -
  • 9.  RE: RIM devices won't connect to WPA2-Enterprise network
    Posted Mar 08, 2012 03:57 PM
    It certainly is responding to the Radius Server's rejection...
  • 10.  RE: RIM devices won't connect to WPA2-Enterprise network
    Posted Mar 10, 2012 11:37 AM
    I use both a blackberry 9900 and playbook w/ v2.0 to connect to the Aruba corporate WPA2-Ent WLAN without any issues, as I recall it worked when I had it setup on a lab SSID as well.
  • 11.  RE: RIM devices won't connect to WPA2-Enterprise network
    Posted Mar 11, 2012 03:03 AM
    Also make sure that you have the server public key loaded into the Blackberry.  I seem to recall that BB auth will fail if the server cert if not available.
     -michael
  • 12.  RE: RIM devices won't connect to WPA2-Enterprise network
    Posted Mar 20, 2012 03:40 PM
    I thought I should give an update on this. RIM is escalating my case to their development team. There is no official word that is a problem with their device, but at this point I can't really see any other possibility.
    I'll let you know what I find out from them.
    Dave
  • 13.  RE: RIM devices won't connect to WPA2-Enterprise network
    Posted Mar 23, 2012 08:27 AM
    Hello Everyone,
    RIM got back to me and linked this KB article:
    www.blackberry.com/btsc/kb29914
    Summary:
    Receiving error "Failed to connect to the network" when attempting to connect BlackBerry smartphone to wi-fi network
    This issue is encountered when secure renegotiation is enabled on the RADIUS server.  The cause of the issue is due to the version of OpenSSL present on the affected BlackBerry smartphones.  The models of BlackBerry smartphone affected by this issue are the 9360, 9380 and 9790 models.
    Resolution: This is a previously reported issue that is being investigated by our development team. No resolution time frame is currently available.
    Workaround: Turn off secure renegotiation on the RADIUS server.
    Like I expected, it looks like Aruba is off the hook!
    Dave
