Risk of upgrading firmware ap 205
  • 1.  Risk of upgrading firmware ap 205
    Posted Oct 19, 2016 10:46 AM
    I have an AP 205 and it's firmware is 6.4.2.0-4.1.1_46936
    And I found this download: http://support.arubanetworks.com/LifetimeWarrantySoftware/tabid/121/DMXModule/661/Command/Core_Download/Method/attachment/Default.aspx?EntryId=22028
    Which looks to be the firmware for this model.
    I am about to try to install this firmware. The thing is that it is a bit scary when you have a "Browse" button and an "Upgrade now" button but no indication that the chosen file in the correct one. I seem to have no way to save the current firmware first, and I am unable to find my current firmware on the internet. am I risking to completely brake my AP if I click "Upgrade now"? Or will it give me more options after I click? Is that file really the proper one?
  • 2.  RE: Risk of upgrading firmware ap 205
    Posted Oct 19, 2016 03:27 PM
    If the file is not compatible, it will tell you so.    The latest firmware for the 205 is located here:
    https://support.arubanetworks.com/DownloadSoftware/tabid/75/DMXModule/510/Command/Core_Download/Default.aspx?EntryId=21788
