We're having a big challenge deploying Remote Mesh Portals. We had these systems working, in lab, with ArubaOS 6.4.3 beta - using AP-274 a year ago. Now we're ready to hang - the RMPs will not come-up correctly. MPs work fine.
When provisioned as RMP:
The RMP will use all IP addresses from a VPN Services/IPSec Address pool - the RMP steps through all available addresses in pool then start over from the pool. Plus, I can only re-provision the RMP after a purge from AP Console.
Attached show:
RMP online - incrementing IP address
2 Children - they never appear
Radios displaying EIRP/MaxEIRP - 0/0 - this is displayed directly after new IP address assignment. I cannot ping the assigned IP.
The AP comes-up fine as a Remote AP.
Tried RMP on AP-325,274,275,225.
Any help is appreciated.
Is it there a tool to compare config files? I would like to load an old config.
ArubaOS - 6.5.1.5
Controller - 7210
Dummy VAP created with split-tunnel and VLAN
Open TAC case #5318429414 28 Mar 2017
Greg Crockett
