Cloud Managed Networks
roaming 11v not working?
This thread has been viewed 26 times
  • 1.  roaming 11v not working?
    Posted May 14, 2024 10:39 AM
    I use two Aruba APs,and configure them with the same SSID name, password and encryption type, and activated the 11k and 11r , but cell phones didn't roam smoothly between two APs,keeping connecting to one AP even if I walkd closed to the other and received RSSI of connected AP is pretty low. So I use wireshark to caputure the wireless packets, however, there's no 11v frame captured, does APIN0555 support 11v? and how can I activate it to assit clients to roam?
  • 2.  RE: roaming 11v not working?
    Posted May 14, 2024 07:48 PM
    is this for Instant APs? and does your clients support 11v?
  • 3.  RE: roaming 11v not working?
    Posted May 14, 2024 09:13 PM
    both are yes
  • 4.  RE: roaming 11v not working?
    Posted May 14, 2024 09:21 PM
    and I haven't found the bottom to enable 11v in AOS 10, is it canceled in OS10 ?
  • 5.  RE: roaming 11v not working?
    Posted May 15, 2024 02:44 AM
    in AOS10 11v is enabled by default.
    Also note that with AOS8.x IAPs, 11v works with clientMatch  service so you need to enable.
