You can try enabling this parameter in the Virtual AP profile:
fdb-update-on-assoc
That would send out a gratuitous ARP when a client enters the forwarding table to ensure that the switch infrastructure is updated:
fdb-update-on-assoc
HPE Design and Deploy Guides:
https://community.arubanetworks.com/support/migrated-knowledge-base?attachments=&communitykey=dcc83c62-1a3a-4dd8-94dc-92968ea6fff1&pageindex=0&pagesize=12&search=&sort=most_recent&viewtype=card------------------------------
Original Message:
Sent: Jun 07, 2024 08:21 AM
Subject: Roaming between 2 clusters in 8.10.x.x
Good morning all.
I have an issue that I can't seem to get to the bottom of. High level, clients cannot roam between APs on different controller clusters. Below are the gritty details.
Scenario - campus setup with 2 clusters (4 controllers on each cluster) geographically separate. Each cluster has it's own management network, but the devices (WLANs) are on the same L2 network. There are a few areas where the RF domain from APs in each cluster overlap. This is where my issue is. When a user is connected to an AP on Cluster A and walks to an area serviced by an AP on Cluster B, the device moves to the new AP but shows as "connected with no internet". The IP address of the device does not change since the L2 for that WLAN is the same across both clusters so I don't think I need to (or should) enable IP Mobility (but I could be wrong there) and I don't think 802.11k would help. The only fix for the end user is to disconnect and reconnect the wifi.
I understand that seamless roaming is only between APs in the same cluster and I'm OK if the device needs to re-authenticate (voice over IP roaming isn't a high priority in this scenario). I just need the device to connect again automatically.
Any ideas?
Thanks!
Jeff
