Roaming between dot11ac and dot11n
  • 1.  Roaming between dot11ac and dot11n
    Posted Mar 26, 2014 12:52 PM
    I'm curious if anyone is running an implementation that has dot11n and dot11ac where the clients roam between.  The Aruba docs mention that if a client is connected to an ac access point it will be hesitant to switch to an n access point and there could be issues if it's going from say 80mhz to 40mhz.  Would the expectation be that there would only be an issue going from ac to n and not the other way around?
  • 2.  RE: Roaming between dot11ac and dot11n
    Posted Mar 27, 2014 04:24 PM
    no takers?
  • 3.  RE: Roaming between dot11ac and dot11n
    Posted Mar 28, 2014 11:41 AM
    I've got no help, but - very interesting question. I'd not considered the impact of this.
    I am looking to deploy my first 802.11ac devices in the next month or two. They'll be located near a bunch of 802.11n devices, so when it's all installed I'll be able to experiment!
    On the face of it, i'd think that by probing a client would be able to successfully identify suitable networks nearby and when joining a new one, configure itself according to the advertised capabilities of the new network.
  • 4.  RE: Roaming between dot11ac and dot11n
    Posted Mar 29, 2014 05:54 PM
    I've got some clients running a mixed implementation and feedback hasn't been bad. i think clientmatch certainly helps but most of the clients are only 802.11n capable anyway so not a huge issue.
    scott
  • 5.  RE: Roaming between dot11ac and dot11n
    Posted Mar 31, 2014 08:51 AM
    I think we would be in the same situation in the beginning where it would just be n clients so I wouldn't expect any issues.  I've heard from other people now that mixing and roaming wasn't an issue for them but it does make mention of it in the Aruba docs
