It looks like your central RADIUS server tries to handle the EAP session, which is suggested by a message around the Outer Tunnel. It should however just proxy the request, in which case the central RADIUS server does not see anything on inner/outer tunnels. If the EAP is handled by that central server, the trusted certificate should be there, as well you probably will see a MSCHAPv2 request coming in, instead of an EAP request. If you ClearPass is not configured to handle those, it's not so strange that you see a timeout.
If RADIUS is proxied over the internet, it could also be that the RADIUS packets are fragmented and dropped somewhere on the route. Deploying Radsec would resolve that issue.
Please be advised that
PEAP-MSCHAPv2 should not be used anymore as it contains broken encryption and you should consider credentials being leaked out if you deploy on devices that you don't 100% control and harden to prevent authentication against a rogue network.
I would as mentioned start by capturing the requests you see coming in through the central server and compare those to the ones coming in direct from your own infrastructure. And you could see if there is retries with large packets which may indicate the fragmentation/MTU issue.
Original Message:
Sent: Nov 04, 2022 07:00 AM
Subject: Roaming SSID not working when my users go to another institution.
I have an issue with an SSID that works like eduroam, just the name of the ssid is different.
My users are going to a different institution connecting on the ssid and failing to authenticate. Their request makes it back to my CPPM servers and shows a timeout.
I can see the request hit the central radius server and the error message displayed is: Reply-Message = Outer Tunnel Rejected! [OUTPUT]: Outer Tunnel Rejected! [Failure-Message]: NONE. The central server is a free radius server.
When I check or local CPPM server it just shows timeout. There has-been no changes on the firewall and this was working beforehand not sure what is causing the issue.
Any pointers will help greatly?
