Rogue AP interpretation change with upgrade?
  • 1.  Rogue AP interpretation change with upgrade?
    Posted Aug 05, 2013 05:21 PM
    Back in 7.4 or 7.5, we tested connecting a rougue AP in to our lab switch and Airwave correctly identified the rogue and sent our NMS and syslog an alert -- all good.
    Today I've plugged in the rogue for a show-and-tell with our PCI assessor and Airwave had elected to declare the AP a "suspected neighbor"
    Did something change in the underlying logic, or were a week of tests missing some crucial bit of testing?
    Lab switch had point-of-sale and client and wireless VLANs trunked to iAP, connect a "rogue" (linksys) to point-of-sale port and connect power. the iAP almost immediately shows the rogue in the IDS page:
    iAP draws the right conclusion
    After a few minutes, I notice that I haven't received the e-mail from Airwave, nor from the NMS or Syslog.
    I check Airwave and it thinks we have a neighbor:
    187-Airwave-disagrees-part-1
    187-Airwave-disagrees-part-2
    What's missing? Or how do I trace Airwave's logic to see where I need to tune it?
    My rules:
    Airwave-rogue-rules
  • 2.  RE: Rogue AP interpretation change with upgrade?
    Posted Aug 05, 2013 09:14 PM
    Did you make any changes to the RAPIDS rules? Which AirWave rule is the classifying rule? Remember that AirWave classification has more options than the controller classification.
  • 3.  RE: Rogue AP interpretation change with upgrade?
    Posted Aug 06, 2013 12:10 PM
    Made no changes.
    In the screenshot, it shows "detected wirelessly" as the classification rule.
    I forgot to add that Airwave is also pliing the switch to which both AP and rogue are connected and should have seen the MAC/ARP entry as well as the iAP -- so I'm expecting "Detected Wirelessly and on LAN" to hit.
    Note that it hit a few months ago when we last tested. The only change has been upgrades to Airwave.
  • 4.  RE: Rogue AP interpretation change with upgrade?
    Posted Aug 06, 2013 12:21 PM
    The configuration looks good to me.  The next step would be to open a support case.  Support will need to do a capture from AirWave of the data gathered from polling the switches (what's the current switch polling period?).
  • 5.  RE: Rogue AP interpretation change with upgrade?
    Posted Aug 06, 2013 01:26 PM
    4 hours (whatever the default was)
    The rogue has been plugged in for 20 hours so far.
    I'm assuming that new information about a device will cause RAPIDS to re-classify an object.
  • 6.  RE: Rogue AP interpretation change with upgrade?
    Posted Aug 06, 2013 01:33 PM
    The quick test of that is to move a rule up, save, and then move a rule back to where it was, save.  It's a wonky way to force AirWave to review classification, but it works.
  • 7.  RE: Rogue AP interpretation change with upgrade?
    Posted Aug 06, 2013 02:32 PM
    No change, unless the reclassification is still running (anyplace to check progress?) so I assume its time to call TAC?
  • 8.  RE: Rogue AP interpretation change with upgrade?
    Posted Aug 06, 2013 03:39 PM
    Yeah, looks like it's time to bring in TAC.
