Higher Education
last person joined: 20 days ago
Got questions on how to enable mobility in education? Submit them here!
Rogue AP Isolation on 2930M
  • 1.  Rogue AP Isolation on 2930M
    Posted Mar 15, 2024 10:25 AM
    Does anyone have experience successfully implementing Rogue AP Isolation on the Aruba 2930M switches? I've run through the setup and feel like I have everything configured correctly, however, I'm still not seeing rogue APs, and I know we have some based on Airwave and our Controller logs.
    Thus far I have configured the following items
    • Enabled rogue-ap-isolation on the 2930M switch (logging only for now)
    • Enabled "wired containment" on our Controller Cluster / AP Group under IDS General
    • Verified LLDP is enabled on the 2930M switch
    Any suggestions, or help, or advice, or lessons learned out there???
    [Matt]
    [Sr. Network Engineer]
  • 2.  RE: Rogue AP Isolation on 2930M
    Posted Mar 18, 2024 05:28 AM
    It's the first time that I hear of this feature. It may not be widely used. As there is a dependency on the AP sending the rogue information, it may (or may not) work with controller based deployments. The documentation seems to be not very specific on the AP/controller side, it does seem that the feature depends on device profiling (aruba-ap devices are mentioned). Did you enable device profiling and do you see your APs profiled correctly? As the communication depends on LLDP, did you enable LLDP on the APs as well?
    If there is no further response here, it may be useful to work with Aruba support and ask them for more details.
  • 3.  RE: Rogue AP Isolation on 2930M
    Posted Mar 18, 2024 11:23 AM
    That's a good question, I will have to check to see if we are profiling our Aruba APs within the 2930M switch.
    [Matt]
    [Director of Infrastructure Services]
  • 4.  RE: Rogue AP Isolation on 2930M
    Posted Mar 19, 2024 04:41 AM
    But please post up how you get on with this, it's a feature I wasn't aware of as well and I will give it a try myself but would be interested to hear your experiences with it.
