Role assignment rules (mac-address)
  • 1.  Role assignment rules (mac-address)
    Posted Jul 28, 2020 06:59 AM
    Just trying to assign a role dynamically based on mac-address... it's not working for me. Does it take MAC addresses without delimiter? Should I use colons : ?
    TIA
  • 2.  RE: Role assignment rules (mac-address)
    MVP GURU
    Posted Jul 28, 2020 08:13 AM
    This is something that never worked for me by using the "Client MAC Address equals <mac with colons>"
    What works for me is doing "Client MAC Address starts-with <mac without colons>"
    See image below and see if this works for you. Not sure why the equals option does not work. It also forces you to use the colons in the mac address.
