role doesn't apply after passed stateful-802.1x
  • 1.  role doesn't apply after passed stateful-802.1x
    Posted Jun 25, 2012 03:17 AM
    Hi all,
       I have some problem about WLAN controller and 3th party AP. I connected AP to Aruba interface and config it as untrusted port then I connected PC with 802.1x authentication after passed authentication Aruba controller didn’t apply role from radius response its got the default role from stateful-dot1x configuration.
    interface gigabitethernet  1/3
    description "GE1/3"
    trusted vlan 1-4092
    switchport mode trunk
    aaa authentication-server radius "IAS"
       host "172.20.43.131"
       key xxxxxx
    aaa server-group "3th_AP"
     auth-server IAS
     set role condition Reply-Message contains "pidgroup" set-value pidgroup
    aaa authentication stateful-dot1x
       default-role "authenticated"
       enable
    UNKNOWN ATTRIBUTE
    Jun 25 03:13:08 :124004:  <DBUG> |authmgr|  NAS_IDENTIFIER_ID:
    Jun 25 03:13:08 :124004:  <DBUG> |authmgr|  NAS_IP_ADDRESS
    Jun 25 03:13:08 :124004:  <DBUG> |authmgr|  UNKNOWN ATTRIBUTE
    Jun 25 03:13:08 :124004:  <DBUG> |authmgr|  USERNAME
    Jun 25 03:13:08 :124004:  <DBUG> |authmgr|  CALLING_STATION_ID
    Jun 25 03:13:08 :124004:  <DBUG> |authmgr|  CALLED_STATION_ID
    Jun 25 03:13:08 :124004:  <DBUG> |authmgr|  EAP_MESSAGE
    Jun 25 03:13:08 :124004:  <DBUG> |authmgr|  Forwarding to the Radius Server(172.20.43.131) len:0
    Jun 25 03:13:08 :124004:  <DBUG> |authmgr|  Forwarding the Radius packet after stateful dot1x processing code:1/smac:00:24:a8:88:4b:8e/sport:32769/dport:1812
    Jun 25 03:13:08 :124004:  <DBUG> |authmgr|  Received Valid Radius Reponse
    Jun 25 03:13:08 :124004:  <DBUG> |authmgr|  EAP MESSAGE
    Jun 25 03:13:08 :124004:  <DBUG> |authmgr|  Forwarding the Radius Response to AP:172.20.43.11 len:0
    Jun 25 03:13:08 :124004:  <DBUG> |authmgr|  Forwarding the Radius packet after stateful dot1x processing code:11/smac:00:0c:29:b0:48:5c/sport:1812/dport:32769
    Jun 25 03:13:08 :124004:  <DBUG> |authmgr|   {L2} Authenticating Server is IAS
    Jun 25 03:13:08 :199802:  <ERRS> |authmgr|  user.c, derive_role2:5623: {38:e7:d8:e7:6a:dc-??} Missing server group in attribute list, auth=Stateful-802.1x, utype=L2
    Jun 25 03:13:08 :124004:  <DBUG> |authmgr|  Adding user: 1090e3b4 (38:e7:d8:e7:6a:dc:0.0.0.0:pid2) to ap group: ap group id: 0
    Jun 25 03:13:08 :124004:  <DBUG> |authmgr|  Tx message to Sibyte. Opcode = 17, msglen = 188
    Jun 25 03:13:08 :124004:  <DBUG> |authmgr|  MM: mac=38:e7:d8:e7:6a:dc, state=3, name=pid2, role=authenticated, dev_type=, ip=0.0.0.0
    Jun 25 03:13:08 :124004:  <DBUG> |authmgr|  Forwarding the Radius packet after stateful dot1x processing code:2/smac:00:0c:29:b0:48:5c/sport:1812/dport:32769
    Jun 25 03:13:08 :124004:  <DBUG> |authmgr|  Tx message to Sibyte. Opcode = 21, msglen = 128
    Jun 25 03:13:08 :124004:  <DBUG> |authmgr|  MAC: 38:e7:d8:e7:6a:dc, No L2 auth configured, L2 Deauthenticate skipped for station.
    Jun 25 03:13:10 :124004:  <DBUG> |authmgr|  Create ipuser 0x0x1095b374 for user 0x0x1090e3b4
    Jun 25 03:13:10 :124004:  <DBUG> |authmgr|  Called ip_user_new() for ip 10.20.20.254
    Jun 25 03:13:10 :124004:  <DBUG> |authmgr|  sta_add_l3: mac 38:e7:d8:e7:6a:dc ip 10.20.20.254
    Jun 25 03:13:10 :124004:  <DBUG> |authmgr|  Adding user: 1090e3b4 (38:e7:d8:e7:6a:dc:10.20.20.254:pid2) to ap group: ap group id: 0
    have anyone get this issue before?
    thanks in advance
  • 2.  RE: role doesn't apply after passed stateful-802.1x
    Posted Jun 25, 2012 11:34 AM
    Are you setting the filter-id on the RADIUS server as  "pidgroup"?
  • 3.  RE: role doesn't apply after passed stateful-802.1x
    Posted Jun 26, 2012 09:19 AM
    Hi hthakker,
       I used Reply-message attribute on radius server not the fillter-id.
    anyidea?
  • 4.  RE: role doesn't apply after passed stateful-802.1x
    Posted Jun 27, 2012 11:44 AM
    @aakmit wrote:
    Hi hthakker,
    anyidea?
    aakmit,
    You should be seeing a message like the following in the user-debug logs.
    Jun 27 07:13:41 :522017:  <INFO> |authmgr|  MAC=e8:99:c4:4e:39:53 IP=10.163.207.102 Derived role 'reply-authenticated' from server rules: server-group=radius, authentication=802.1x
    Following is my configuration
    aaa server-group "radius"
    auth-server hthakker
    set role condition Reply-Message contains "reply123" set-value reply-authenticated
    Can you check if the the RADIUS server is sending out Reply-message in the Access-Accept message.
    You can get packet capture on the RADIUS server and filter with "radius".
    Attribute Value Pairs inside the Access-Accept packet
    AVP: l=10  t=Reply-Message(18): reply123
  • 5.  RE: role doesn't apply after passed stateful-802.1x
    Posted Jun 27, 2012 02:11 PM
    aakmit,
    If you do not have the capability to get packet capture on the RADIUS server, you can check if the server is responding with the Reply message on the controller itself.
    (master) (config) #logging level debugging security subcat aaa
    (master) (config) #logging level debugging security process authmgr
    (master) # aaa test-server mschapv2 <radius-server> <username> <password>
    (master) #show log all | include Reply
    Jun 27 09:42:32 authmgr[1579]: <121031> <DBUG> |authmgr| |aaa| [rc_api.c:989] Reply-Message: reply123
    Also,
    Can you post the output of the following command?
    show aaa authentication wired
    HT
  • 6.  RE: role doesn't apply after passed stateful-802.1x
    Posted Jun 28, 2012 03:15 AM
    Hi hthakker,
    thanks for your answer. I captured packet on radius server and i saw the Reply-message return attribute list in the radius packet.
    Then i tested with aaa test-server command i got the resault like below.
    Jun 28 06:03:37  authmgr[1565]: <121031> <DBUG> |authmgr| |aaa| [rc_api.c:989]  Reply-Message: pidgroup
     So, I'm pretty sure the radius return attribute correctly but i don't know while server rule doesn't apply to user.
    (WLAN) #show aaa authentication wired
    Wired Authentication Profile
    Parameter    Value
    AAA Profile  wire-authen
    (WLAN) #show aaa profile wire-authen
    AAA Profile "wire-authen"
    Parameter                           Value
    Initial role                        logon
    MAC Authentication Profile          N/A
    MAC Authentication Default Role     guest
    MAC Authentication Server Group     N/A
    802.1X Authentication Profile       N/A
    802.1X Authentication Default Role  guest
    802.1X Authentication Server Group  N/A
    L2 Authentication Fail Through      Disabled
    RADIUS Accounting Server Group      N/A
    RADIUS Interim Accounting           Disabled
    XML API server                      N/A
    RFC 3576 server                     N/A
    User derivation rules               N/A
    Wired to Wireless Roaming           Enabled
    SIP authentication role             N/A
    Device Type Classification          Enabled
     Enforce DHCP                        Disabled
    (WLAN) #
    thanks in advance.
  • 7.  RE: role doesn't apply after passed stateful-802.1x
    Posted Jun 28, 2012 06:46 PM
    aakmit,
    Try using the following configuration instead of "stateful-dot1x"
       key xxxxxx
     auth-server IAS
    aaa profile "3th_AP-aaa"
    authentication-dot1x "3th_AP-dot1x_prof"
    dot1x-default-role "authenticated"
    dot1x-server-group "3th_AP"
    aaa authentication dot1x "3th_AP-dot1x_prof"
    Apply the "aaa profile" under the Virtual AP profile if the client is connected through an SSID of apply to the wired interface if the client traffic is coming through an untrusted wired interface
    Hope it helps !
    HT
