Role mappping - using a previously defined Role to generate another one
  • 1.  Role mappping - using a previously defined Role to generate another one
    Posted Jul 02, 2018 07:32 AM
    In a role mapping file I've got an entry that defines whether a client endpoint is an allowable airgroup device and assign a locallly defined roll to it of "Airgroup Shared Device" ( see below )
    and have set up an equivalent for games consoles.
    I'm setting up a WPA2-PSK network only for either "Airgroup Shared Devices" or "Game Consoles" and want to create a Role called "UoY PSK Device" where the logic is
    if (Radius:Aruba:essid = "airgroups-psk" AND ( Role=Airgroup Shared Device OR Role="Game Console") )Then assign role " UoY PSK Device"
    Can I create the above ? in a Role mapping file that also defines the OR components?
    Failing that, could I do
    if (Radius:Aruba:essid ="airgroups-psk" AND Role=Airgroup Shared Device) then ....
    and repeat it for games consoles.
    Role mapping entries only seem to be if and..and..and... or IF...or...or
    Rgds
    Alex
    44.(Authorization:[Endpoints Repository]:Device Name  CONTAINS  Apple TV)
    OR  (Authorization:[Endpoints Repository]:OS Family  CONTAINS  Chromecast)
    OR  (Authorization:[Endpoints Repository]:OS Family  CONTAINS  Roku)
    OR  (Authorization:[Endpoints Repository]:Device Name  EQUALS  Amazon FireTV)
    OR  (Authorization:[Endpoints Repository]:OS Family  CONTAINS  Sonos)
    OR  (Endpoint:UoY_Airgroup_Shared_Server_Device_v2  EQUALS  true)
    OR  (Authorization:[Endpoints Repository]:OS Family  EQUALS  Solstice)
    OR  (Authorization:[Endpoints Repository]:Device Name  EQUALS  Amazon Echo)
  • 2.  RE: Role mappping - using a previously defined Role to generate another one
    Posted Jul 02, 2018 09:15 AM
    ok. found the "belongs to statement" so i can build if ssid=... and client belongs to < list of categories or devicve types> which will do
    A
