role to route map traffic
  • 1.  role to route map traffic
    Posted Jan 27, 2017 09:50 AM
    I would like to create a role that will routemap traffic,  traffic to specific subnets should route regular and the rest route into a GRE tunnel on the controller,  does anyone have an example or can point me in the right direction, we do not do anything like this now so my first foray into managing traffic with the controller.
    Thanks.
  • 2.  RE: role to route map traffic
    Posted Jan 30, 2017 04:45 AM
    Couple of ways I can think to do this.
    1. You could have the default gateway at the other end of the GRE tunnel, then use the controller routing table to route the other traffic.
    2. Use ESI routing for the routes to networks you don't want to go down the GRE tunnel then you could have an "user any any route GRE" rule at the end of your role.
